My API console says I have errors. How can I see the error details through the Console. The Endpoints did not provide the error detail, just some times. I need the error detail to troubleshoot.
Thank You,
Jay
Thank You,
Jay
For clarification, when I say API Console, I mean the API App info listed on:
https://developers.ringcentral.com/my-account.html#/application-dashboard
I'm writing an ASP.Net web forms application, not a .Net Console application.
Which API are you using?
The first step is test your API in https://developers.ringcentral.com/api-reference/ or in a postman tools with all the input data.
If it still gives you an error there, not the HTTP error status, API response and put here.
We can then troubleshoot the issue.
Which authorization method should an ASP.Net application use?
Can you point me to a code sample in C#?
The samples i saw seemed to use password-flow, yet in other places I saw that only console apps can use password flow.
When I was setting up my API App, the QuickStart said that the most common App Type was 'Web server.' However, I could not find a C# code example for Authorization from Web server.
My code (in VB.Net but happy to work from C#)
Dim restClient As RestClie restClient = New RestClient(RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, RINGCENTRAL_PRODUCTION) restClient.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD).Wait() Dim parameters = New MeetingRequestResource() parameters.topic = "Test Meeting" parameters.meetingType = "Instant" parameters.allowJoinBeforeHost = True parameters.startHostVideo = True parameters.startParticipantsVideo = False Dim resp = Await restClient.Restapi().Account().Extension().Meeting().Post(parameters)
The code never returns a response from Dim resp = Await restClient.Restapi()..... and no exception is thrown.
3 People are following this question.
