saadetswift16514 avatar image
saadetswift16514 asked saadetswift16514 answered
Default Location of Saved RingCentral Meetings Recording
You can change the Default Location where RC Meetings will save after youve recorded.
If you often record your RingCentral Meetings and want to change where they save on your computer, follow the steps below.
1) Go to your Settings on the Meetings Application
2)      On the left-hand side go to the Recording Location section
3)      Click on the Change File Location button
4)      Select the location you want your recordings to save to
If you want the ability to change the location after every recording, simply check mark the box below the Recordings Location and once the meeting ends it will prompt you for the location you want the recording saved to.
rc meetingsrecordingdefault location
Want to learn more? Check out and follow our Tip of the Week Index
