Hi All,
I am creating a dummy console application using ASP.NET with C# and RingCentral.Client.
After implementing provided sample code, I got below error:
Please suggest what is the step which I missed.
Hi All,
Hi Raman,
Not sure how you created the auth request. But the first thing I would suggest is to use the new RingCentral .Net SDK. Then follow the sample code to get authenticated.
Example to make a ring-out call
If you still want to authenticate the way you did before. Post the entire code (don't post your username/password nor client Id/Secret) so I can help.
Hello Phong,
Below are the steps which I follow
1. I created the app with below settings
2. Created an dummy console project in VS-2015 having below environment
3. Installed RingCentral.Net and Newtonsoft.json from nuget:
4. As suggested in your tutorial, I write the below code on program.cs
5. After running the application I get the below error:
Let me know which step I missed or why not application get authorization as suggetsed.
Thanks,
Raman Thakur
400 (Bad Request means you are not able to provide correct request to the oauth API.
Did you checked by calling the API directly? It can happen due to various issues.
Until and unless you provide the full exception message and the full details about how you are calling the token url, and details about your input, it will be difficult to judge.
Thanks,
Raman Thakur
1 Person is following this question.
