Data Archival API avatar image
Data Archival API asked Anirban Sen Chowdhary edited
In order to call this API endpoint, user needs to have [ReadCompanyCallLog] permission.
I am not able to read [Get Company Call Logs Records] API,
App Permission
ReadCallLog
User Permission
FullCompanyCallLog
Usage Plan Group
Heavy
params = {
    'view': 'Simple',
    'dateFrom': '2019-08-04',
try:
    resp = platform.get('/restapi/v1.0/account/~/call-log', params)
api permissions
Phong Vu avatar image
Phong Vu answered Phong Vu edited
It means that in order to read the call log of an entire account (call data of all extensions under an account) you need to login with the admin extension 101 or other extensions with the admin role.
If you login with a normal user extension (User role) use this endpoint '/restapi/v1.0/account/~/extension/~/call-log'
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered Anirban Sen Chowdhary edited
The main reason is this is an admin root access level to read the company level log and access the call log of all extension under the account.
Active Calls, Account level Call Log Records, and Extension level Call Log Records require the ReadCallLog API permission.
ref: https://developers.ringcentral.com/guide/voice/call-log/reading-call-log
more info: https://forums.developers.ringcentral.com/questions/162/call-logs-for-individual-accounts.html
