ak avatar image
ak posted daisy-itty16505 commented
Setup in the Sandbox Environment
Below is the information on getting you started on the Sandbox Environment.
1) Sandbox Environment User Credentials
If you are on Sandbox Environment,  follow the below steps to get your sandbox account credentials:
  1. Login to https://developer.ringcentral.com/ using your Developer Platform credentials (RC account credentials)
  2. Go to your Sandbox Account page: "My Account > Sandbox Account". Locate the "Main Company Number" which will be your username when formatted in E.164 format, (example: +12223334444).
  3. The password is the password you received via email when you created the sandbox account, unless you have changed the password.
The above credentials can also be used for logging into, and reset at, the Online Account Portal for Sandbox Environment at: https://service.devtest.ringcentral.com/
2.) Create an Application on Sandbox Environment
  2. Under Applications -> Create a new Application as per your requirements.
  3. To retrieve app key and secret key : Find your application key and secret by clicking on My Account -> Applications -> Application Name. Use Sandbox Application key and secrets
3.) RingCentral API Explorer
The easiest way to start testing our APIs would be by using our  API Explore here  http://ringcentral.github.io/api-explorer/. You can start filling out your RC sandbox credentials and start going from there. We have self explanatory documentation in the link above
4.) Documentation
You can find all the necessary documentation with our APIs could be looked up here at :  https://developer.ringcentral.com/api-docs/latest/index.html
topic-default
18 comments
1 |1000
ak avatar image ak commented ·
Hi Jude,
The error that you are seeing could have been due to multiple attempts on sandbox account creation. If you are still getting the same error message while you create a sandbox account, please log a case with 'devsupport@ringcentral.com' with your RC account details :
https://developer.ringcentral.com/support.html
jude-vinnarasi-elizabeth357 avatar image jude-vinnarasi-elizabeth357 ak commented ·
Thanks Anil!
jude-vinnarasi-elizabeth357 avatar image jude-vinnarasi-elizabeth357 commented ·
I couldn't create any sandbox account for my account. I'm getting error like 'Oops! It seems like something went wrong with your last sandbox account creation. Please try again!'. let me know anyone have idea about this.
Thanks in Advance!
gmclean418 avatar image gmclean418 jude-vinnarasi-elizabeth357 commented ·
Jude, I am having the exact same issue. Did you ever reach a resolution?
gmclean418 avatar image gmclean418 commented ·
I am having the exact same issue as Jude above. I have submitted a support case and am hoping for a resolution.
Could you please try again to create a sandbox account and verify it if you are able to successfully create one.
Thanks.
Anil, I tried again with the same error result. "Oops! It seems like something went wrong with your last sandbox account creation. Please try again!"
I have submitted support cases 04156804 (and before that, 04151632) with no results. We have tried to gain access to your faxing API for weeks now, and frustratingly, we still do not have it. If RingCentral does not grant us access shortly then we will choose another solution.
ak contributed to this article
