Geordano avatar image
Geordano asked Geordano commented
Tracking incoming calls and IVR option selected
Hi.
I have created an application that integrated our web intranet using the Embeddable widget.
Now I want to keep track of the incoming calls and see what options they have selected in the IVR
I have tested the API / Call-Log / active-calls but I don't see IVR information
Is it possible to get that information with from the API, or from the Embeddable widget?
Thanks in advance!
ivrcallstracking
Phong Vu avatar image
Phong Vu answered
I am checking around but could not find the capability to track IVR option. I think it is not possible but let me search more and get back to you as soon as I can.
Geordano answered
Thank you!
I have continued investigating and I have seen that if the name of the last call queue you entered is saved in the call log.
In the administration portal if that information is visible, in the detailed call log.
Any help would be good
Greetings and thanks!
Geordano answered
@Phong Vu
I have also seen at the endpoint Call-Log/listCompanyActiveCalls
In the legs property, there is a list of the extensions the call has passed through.
That's right?
If so, I think that information is what I am looking for.
But apparently it's only on active calls.
And I want to extract this information from the API to generate a log. Where could I get it from?
Phong Vu answered Geordano commented
I don't think that they are recorded in the call legs because they are the DTMF tones.
Geordano avatar image Geordano commented ·
Yes? I thought it was the jump the call.
Well, I hope you can help me with this information.
At the moment I am going to save the call information returned by the embeddable web widget "rc-active-call-notify" event.
Have a nice day!
