Generational IT Admin avatar image
Generational IT Admin asked Generational IT Admin commented
Searching for Documentation for the Legacy C# SDK
We ran into the same .NET Framework compatibility issue as described in this post (https://forums.developers.ringcentral.com/questions/9674/how-to-add-ringcentral-nuget-for-net-452.html).
So we are using the legacy SDK found here (https://github.com/ringcentral/ringcentral-csharp).
I've read through the documentation found here (https://ringcentral-csharp.readthedocs.io/en/latest/).
But I have not been able to find anything about how to make a call out. Is there other documentation out there about the legacy SDK?
.net sdkdocumentation
Phong Vu avatar image
Phong Vu answered Generational IT Admin commented
The C# SDK is deprecated and we are not going to maintain or update it. What is the restriction on using the new .Net SDK for you?
Generational IT Admin avatar image Generational IT Admin commented ·
We get this error when trying to install it:
Could not install package 'RingCentral.Net 3.2.0'. You are trying to install this package into a project that targets '.NETFramework,Version=v4.5', but the package does not contain any assembly references or content files that are compatible with that framework. For more information, contact the package author.
