January Tidbits
SMS Questions Answered
You've got SMS questions; We've got Answers!
kailashvasan vk avatar image
kailashvasan vk asked kailashvasan vk commented
Embedded app - Call startTime format is as "1591774064578". when we access this from the Windows.Phone.CallLogs.Calls object. Please help on the format
embedded widget
Phong Vu avatar image
Phong Vu answered kailashvasan vk commented
It is the timestamp rather than the time. If other time fields in that call log is the time, then it is a mistake that the app does not convert the timestamp to the time. If all the time fields are the same or that is the only time field, then it might be logged as a timestamp (based on UTC time) on purpose to make it easy to convert to a local time. You can convert the timestamp to a time e.g. in Javascript as follow:
var startTime = new Date(callStartTime).toISOString()
kailashvasan vk avatar image kailashvasan vk commented ·
Thank you. It worked!
