January Tidbits
SMS Questions Answered
You've got SMS questions; We've got Answers!
kailashvasan vk avatar image
kailashvasan vk asked kailashvasan vk commented
How to stop/pause and release the recording in embedded app, once the automatic call recording is enabled in the ring central admin portal
recordings
Phong Vu avatar image
Phong Vu answered kailashvasan vk commented
I believe that once the call is connect, the user will see the Recording toggle button Stop/Start or something like that on the widget UI.
If you meant to toggle programmatically, I don't think that it is possible because you will need to have a telephonySessionId and the partyId of the call to call the API.
kailashvasan vk avatar image kailashvasan vk commented ·
In the UI, if we click on that Recording button (start/stop), it says "You cannot record the call at the moment. Error code: -8" The call is already active it says in audio. Because we have enabled the auto recording in the admin portal. please help suggest a solution where a pause/resume recording should be available for the user, like keyboard short cuts given below for a RC APP
https://support.ringcentral.com/s/article/10665-automatic-call-recording-enable-disable?language=en_US
