Ravi Jain avatar image
Ravi Jain asked Ravi Jain commented
Testing fax without real fax machine
How can we test fax if we don't have a remote fax machine?
Do we always need a physical fax machine to test the fax everytime? Or there is some way to test fax as demo?
fax api
Anirban Sen Chowdhary avatar image
Anirban Sen Chowdhary answered Ravi Jain commented
If you check this:
https://stackoverflow.com/questions/49864445/how-to-test-ringcentral-fax-api-without-sending-to-real-fax-machine
seems that the solution mentioned there is to create two sandbox fax numbers and send from one number to the other. Since, sandbox account provides multiple numbers, this seems too be a good way to test the fax and also receive the fax without using real number or machine device.
Ravi Jain avatar image Ravi Jain commented ·
make sense.. thanks
