Lucas Heneks avatar image
Lucas Heneks asked drake-zhao commented
widget tutorial error
We are investigating the possibility of using a chrome extension. I attempted to follow along with this tutorial: https://ringcentral-tutorials.github.io/build-chrome-ringcentral-widgets-extension-for-crm/#0
However, at step 3, when loading the extension from the dist directory, chrome reports an error:
There isn't much for me to change in the steps of the tutorial, just couple of npm calls and config.js changes described in the tutorial. Does anyone have any ideas for getting it working?
extensionjavascript
Embbnux Ji avatar image
Embbnux Ji answered
Hi Lucas, it seems there are issues in `background.js` file that generated and built by ringcentral-embeddable-extension-factory
I created a issue here https://github.com/ringcentral/ringcentral-embeddable-extension-factory/issues/32 to follow it
drake-zhao avatar image
drake-zhao answered drake-zhao commented
Lucas,
You may try create the app again, I have updated the template. Let me know if you have any problem.
npx ringcentral-embeddable-extension-factory my-app
2 comments
Lucas Heneks avatar image Lucas Heneks commented ·
Thank you Drake, I have tried it again and still receive the same error. I should have mentioned this is using the SPA option from the factory in case that makes a difference.
drake-zhao avatar image drake-zhao Lucas Heneks commented ·
Lucas, still can not reproduce this error, can you have a meeting with me to check it, just give a time/timezone to drake.zhao@ringcentral.com next week.
