Ellen Sleight avatar image
Ellen Sleight asked Ellen Sleight edited
PHP SDK Class not found
I installed the RingCentral PHP SDK.
I created the "ringout.php" file.
When executing it, it says "PHP Fatal error: Class 'RingCentral\SDK\SDK' not found...", which it isn't.
What am I missing?
$rcsdk = new RingCentral\SDK\SDK($RINGCENTRAL_CLIENTID, $RINGCENTRAL_CLIENTSECRET, $RINGCENTRAL_SERVER);
php sdk
Phong Vu avatar image
Phong Vu answered
Do you see the "/vendor/ringcentral/" folder under your project folder? Or check if that exists where you install SDK into.
Ellen Sleight answered Phong Vu commented
Yes. I see vendor/ringcentral and all of the other files.
My script includes (variables below are defined)
require('vendor/autoload.php');
use RingCentral\SDK\SDK;
$rcsdk = new SDK($RINGCENTRAL_CLIENTID, $RINGCENTRAL_CLIENTSECRET, $RINGCENTRAL_SERVER);
and I actually echoed variables to the screen to make sure each file was included (as I executed from the Linux command line)... It does include SDK.php.
The error specified is on the line where it says "new SDK" ( figured I'd mention it).
Also... I noticed that the autoload_classmap.php file is basically empty. Unsure if this should be the case:
<?php
// autoload_classmap.php @generated by Composer
$vendorDir = dirname(dirname(__FILE__));
$baseDir = dirname($vendorDir);
return array(
Phong Vu avatar image Phong Vu ♦♦ commented ·
I believe it is about your environment. I found this discussion on stack overflow that may help you.
Ellen Sleight answered Ellen Sleight edited
I saw this discussion as well. I did the below and it is bool(true).
I even echo debug output from SDK.php and it works... although, it doesn't see the class SDK when I do get_declared_classes().
<?php
var_dump(file_exists("vendor/autoload.php"));
