I am integrating WebRTC into the AngularJS application, just trying to login with 'password flow' but cause by below issue:
Error:
Can someone please help me out to resolve the error?
Thanks, Jeetendra
Error:
Thanks, Jeetendra
What version of webphone SDK are you using ? I found out a bug on SDK 0.8.1 but i dono if this issue is related to that. Can you please use v0.8.0 and test the same ?
Can you provide me full log from your app for investigation by running this app -> https://ringcentral.github.io/ringcentral-web-phone/
Vyshakh
getting the same error after changing the SDK version 0.8.0
I am using 0.8.1 version of SDK and I have tried on provided link but getting same error as below:
Not able to proceed for call, when call is placed its directly hang-up.
It is actually a cert expiration issue. We are renewing the certificate asap.
Please stay tuned.
4 People are following this question.
