joseph-mazzarella13062 avatar image
joseph-mazzarella13062 asked Phong Vu commented
Have an active subscription for SMS, but not receiving any webhook events
I use AWS lambda running node JS. In my service, I have established a subscription, but I receive no events whatsoever.
this is the subscription:
    "uri": "https://platform.devtest.ringcentral.com/restapi/v1.0/subscription/eb55a123-1f0f-46c4-9c90-cbe8554616c7",
    "id": "eb55a123-1f0f-46c4-9c90-cbe8554616c7",
    "creationTime": "2020-07-08T20:18:12.960Z",
    "status": "Active",
    "eventFilters": [
        "/restapi/v1.0/account/247984004/extension/247984004/message-store/instant?type=SMS"
    "expirationTime": "2020-07-15T20:18:12.960Z",
    "expiresIn": 538066,
    "deliveryMode": {
        "transportType": "WebHook",
        "encryption": false,
        "address": "https://api.dev.orangetheoryfitness.net/sms/v1/smsreply"
Any help appreciated
webhooks
Phong Vu avatar image
Phong Vu answered Phong Vu commented
Look like this address (https://api.dev.orangetheoryfitness.net/sms/v1/smsreply) is not publicly accessible. It seems AWS api endpoint requires authentication token.
you can test your app on a local machine to double check if your webhook setup is working well.
6 comments
joseph-mazzarella13062 avatar image joseph-mazzarella13062 commented ·
I doublechecked. It is open to the public endpoint.
Please try this:
curl --location --request POST 'https://api.dev.orangetheoryfitness.net/sms/v1/smsreply' --header 'Validation-Token: Mytesttoken' --data-raw '' -v
when I create a subscription, I get a response back to confirm the endpoint. it just contains no data. and after that anytime I send or reply to the SMS messages I get no events at all.
Phong Vu avatar image Phong Vu ♦♦ joseph-mazzarella13062 commented ·
Did you test your app on your local machine? E.g. using ngrok.
If it works on your local machine and not work on AWS, then there is some issue with the delivery address or access problem with AWS API gateways.
joseph-mazzarella13062 avatar image joseph-mazzarella13062 Phong Vu ♦♦ commented ·
It does not receive events from RingCentral. Events are not delivered to a public endpoint, as specified in my OP. Everything in my system works, it connects to RC, logs in, creates subscription, sends SMS messages as required. But it does not receive the Webhook events from RingCentral when the emails are replied to.
