nibu-eapen10876 avatar image
nibu-eapen10876 asked Phong Vu answered
Exception: Parameter [nickName] value is invalid
I'm keep getting this error. I tried all possible values.
Exception: Parameter [nickName] value is invalid  SDK HTTP Error at https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/address-book/contact/  Response text: {    "errorCode" : "InvalidParameter",    "message" : "Parameter [nickName] value is invalid",    "errors" : [ {      "errorCode" : "CMN-101",      "message" : "Parameter [nickName] value is invalid",      "parameterName" : "nickName"    } ],    "parameterName" : "nickName"  }
topic-default
Phong Vu avatar image
Phong Vu answered
Hi Nibu,
How do you call that endpoint and did you call the API without any parameter? Can you just quickly test that with the API Explorer to see if you get the same error. Please try and let me know to further investigate your problem.
+ Phong
