geoffrey-forbes avatar image
geoffrey-forbes asked mike commented
Error message "URL disabled"?
dhcpurl disabled
5 comments
Office , Are you having an issue?  If you have a case number please reply with it so we can escalate it for you.
Mike
office1 avatar image office1 commented ·
I have had a case number for 7 days
Please reply with the case number.
03967129
Case number has been sitting out there for 7 days now, if going on a chat board resolves the problem that says something about customer service. Though it took about 7 days last time to fix the same exact problem
Thank you. I've escalated this and we'll get someone to call you as quick as we can.
Bruce Browning avatar image
Bruce Browning answered
I'm having this issue now. Qos test is fine. Can anyone help?
mike avatar image
mike answered
"URL Disabled" is usually due to an internal network issue.
  1. First thing you want to check for is: Is the phone getting an IP Address? If the phone does not have an IP Address, then have your IT Dept troubleshoot your internal network.  Try rebooting your modem/router and check the DHCP.  DHCP Error on the phone indicates the phone is not pulling an IP Address.  Please let your IT Dept know so they can troubleshoot the internal network.  RingCentral cannot do anything if it's not pulling an IP Address.
  2. Follow the troubleshooting steps provided in this Knowledge Base: Resolving  URL Call Disabled error
  3. If it is getting an IP Address, reboot the phone (unplug it from the power supply for 30 seconds and plug it back in).  If the issue continues after completing the steps provided in the article above, open a web case and provide the Ext Number & Serial Number.
eileenk4491 avatar image
eileenk4491 answered mike commented
I have this issue on three phones. They all started at about the same time but at three different locations. The only thing in common is they are the phones that ring when the outside world called the advertised telephone number. I've been working with RC support for hours.
The phones have static IPs and no Internet or network problems at any other devise at the branch. All of the other phones are the same make and model. All other phones work fine. I'm stumped. They are stumped. It is now at Tier 3 support.
EileenK,  Just wanted to followup on this. I found a recent case but it shows that it was closed yesterday. Please reply back if there are still issues. Thanks!
Mike
