bob avatar image
bob asked
Why can't I send a test fax to myself?
I just set up RingCentral and created a test fax and sent it to myself. I received the following email message back.
When we tried to send your fax, our system detected that you have multiple accounts with the same trusted email address. Your fax could not be sent because we were not able to determine which account to use.
Please log into the accounts that you do intend to send faxes from and remove your email address from the trusted list by clicking Preferences and then Fax Settings.
Thank you for using RingCentral.
Not sure what to do.
can't send a faxtest faxfaxing issuesfaxing email error
