Yvette Camacho avatar image
Yvette Camacho asked walter-bacon answered
View Fax transmission report
I've seen one other post about this and want to get an answer from the company on it. Is there a way to print the single page fax transmission report for each fax that I have sent using my RingCentral fax account?  Ideally this would be exactly like the fax transmission report that you can print from a physical fax machine which has part of the first page that was faxed.  I need this for legal purposes to prove documents were faxed to the recipients.  Thanks.
topic-default
walter-bacon avatar image
If you're looking for a response from a ringcentral rep, your best be would be to make a ticket.
However, when you get an answer, please post whatever the answer is here, for the community's sake. =)
