April Bickle avatar image
April Bickle asked Chuck Fuscone answered
how do i set to receive calls from one number, but call out from multiple numbers
topic-default
Chuck Fuscone avatar image
Hi April, your account needs to have the numbers you wish to dial out on adjusted so you have a company number for each one you want to dial out on.
Then you could accomplish the switch by changing the Outbound caller ID in your extension setting
Hope this helps
Chuck
Certified Ring Central Installer
ckfuscone@yahoo.com
