gary-lindner avatar image
gary-lindner asked Chuck Fuscone commented
Program a line key on a VVX 310 as a Speed Dial to an outside number
How do I program a line key on a VVX 310 as a Speed Dial to an outside number?
speed dail
gary-lindner answered Chuck Fuscone commented
Thanks very much for the reply, Chuck.  This is what I tried.  1)  Created Extension w/o phone; 2) In User Info, entered outside number as Contact Phone. 3) Screening and Greetings all turned off. 4) Handling and Forwarding - Home number Active with 4 rings; 5) Messages & Notification - Take Message turned off; 6) On my phone under Presence selected that extension.
Name of Extension is displayed on Phone.  When I press the line key (without picking up the handset)  I get music onhold and the display shows "blf380204020".  The called party gets caller ID "Unknown" and an answer prompt that says the name I assigned to the extension.  Is there a way to get it to just ring and to send Caller ID from my own line?  Thanks again for your help.  Gary
Chuck Fuscone avatar image Chuck Fuscone commented ·
Just missing one thing.  Instead of putting the number you want to call in the Contact Phone. go to Call Handling and fill in a number in one of the fields.  Mobile, or Home or work.
Does not matter, they will all function the same
Other items to turn off is the call forwarding to smart phone under call handling and turn off the voice mail
You should be good to go
let me know
Chuck
Certified Ring Central Installer
ckfuscone@yahoo.com
Chuck Fuscone answered
Create another Extension in your Ring Central system that in the call handeling has that number.  Turn off screening and other non essential items, then assign that extension to a button.
when you press the button, the system will dial out
Chuck
Certified Ring central Installer
ckfuscone@yahoo.com
