No matter what I do I always receive "3 - No recipients specified" when attempting to use the Faxout api. I have tried using a "1" in the Username and Recipient fields to no avail. Here is my php code. I have also tried converting is field to ascii without any difference.
It would be great if there were some documented PHP code examples we could use.
$postURL = ' https://service.ringcentral.com/faxapi.asp';
$ch = curl_init($postURL);
curl_setopt($ch, CURLOPT_USERAGENT, 'Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.9.2.13) Gecko/20101206 Ubuntu/10.10 (maverick) Firefox/3.6.13');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_HEADER, 0);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($ch, CURLOPT_MAXREDIRS, 5);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_VERBOSE, true);
curl_setopt($ch, CURLOPT_REFERER, ' http://www.google.com/');
$hiddens = '';
$hiddens .= 'Username'.'='.'1xxxxxxxxxx'.'&';
$hiddens .= 'Password'.'='.''.'xxxxxxx';
$hiddens .= 'Recipient'.'='.'15138211111|John Doe'.'&';
$hiddens .= 'Coverpage'.'='.'NONE'.'&';
$hiddens .= 'Coverpagetext'.'='.'asdf asdf'.'&';
$hiddens = urlencode(substr($hiddens, 0, strlen($hiddens)-1));
$hiddens = (substr($hiddens, 0, strlen($hiddens)-1));
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, true);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 2);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $hiddens);
$page = curl_exec($ch);
echo $page;// output result
if ($page === FALSE) {
var_dump(curl_getinfo($ch));
exit( "Post: FAILED = ".curl_error($ch) );
curl_close($ch); // close the connection
$hiddens = '';
