Rosa Isela Gomez avatar image
Rosa Isela Gomez asked Rosa Isela Gomez commented
Is support down for submitting tickets?
I been trying to submit a ticket and it just loops back to the screen.  I logged out and back and same result.
topic-default
Thomas D avatar image
Thomas D answered Rosa Isela Gomez commented
I have also found that Internet Explorer doesn't work with the ticket submission process. I have to use Firefox or chrome.
4 comments
Thomas D avatar image Thomas D commented ·
I think I just fixed it. It's with Internet Explorer version 11. But if RingCentral is in the "Compatibility Mode Settings" then it doesn't work. If I remove it, it works.
attached is what it looks like in compatibility mode.
Do you know which version of IE you were using?  And where did you run into a problem? Or did you get some sort of error message?
Mike
Notice in the screenshot, I chose "User Settings" but the sub-menu didn't appear.
Rosa Isela Gomez avatar image Rosa Isela Gomez commented ·
Thanks,  that worked!
mike avatar image
mike answered
Hello Rosa Isela Gomez,
This sounds like a browser caching issue. Try to clear your cache, then close the browser, reopen it and then log back in and try again Or you can also try a different browser, ie Firefox, Chrome etc.
Mike
