Brian Home avatar image
Brian Home asked mike answered
Google Drive Send PDF
I need to be able to fax PDF files via the GOOGLE DRIVE. I scan into Google Drive files and they appear as PDF files. I have 2 scanners than can automatically upload the file to the Google Drive and it appears there as a PDF. I know I can do Ring Central fax to email but I would prefer to scan, have it uploaded to google drive, then fax it out. Right now all you can fax out is a DOCUMENT, which is very limited
topic-default
mike avatar image
mike answered
Do you have the Google Drive app installed on your computer?  You should be able to initiate this from the Softphone.  When you click the attachment/paperclip icon, it will let your browse your computer for the file. The Google drive should show up on the left side of the window like your local hard drive and allow you to attache the file.
Mike
