joel avatar image
joel asked mike answered
Login failure
When I hit the login button, it brings up a blank box on the upper left side of the screen. This has been going on since early March 20, 2015. This needs to get fixed immediately. I called the support line and it says to got to the website to check for errors, then does an automa up. You call that support... riiiggghhttt....
topic-default
mike avatar image
mike answered
Hi Joel,  Start by doing a password reset on the main account.  Here are the steps.  Resetting your account password
Then once you have the password reset, try to log back into the Softphone again.  If for any reason that does not work, then use this link to  Open a Case and tell us which phone number the problem is with.
Thanks!
Mike
