Stephen Karpf avatar image
Stephen Karpf asked mike commented
How do I send a fax, from email, to a fax line which is an extension and requires selecting a number?
Don't know how to send fax to a fax line on an extension.
topic-default
Question different than original topic Please reference the new conversation here: How can I send a pdf to a development account?
mike avatar image
mike answered mike commented
Hi Stephen,  Try sending the fax with the following format: "10 digit phone number * extension number" so it looks like:   xxxxxxxxxx*xxx@rcfax.com
This may not work depending on the receiving machine. You are sending to another number outside of RC, I'm not sure if the receiving system will recognize the " * " symbol, so you'll probably want to test it and follow up with a phone call to assure they received it.
Note:  This will not work when sending to a RingCentral number. Faxes to RingCentral must be sent to just the 10 digit number.
Mike
2 comments
Stephen Karpf avatar image Stephen Karpf commented ·
Worked to a non-RC line which was asking for a menu selection to receive a fax! Thank you.
Great!  Glad I could help.  Thanks for the follow up!
