Bruce Browning avatar image
Bruce Browning asked mike commented
getting url is disabled message
I get this from time to time. Not is a time. Can someone help? Internet connection is fine.
topic-default
Andy Sheppard avatar image
Andy Sheppard answered mike commented
Same issue.  75M line.  Port forwarding correct.  DNS correct.  Randomly, phones will die ("URL call disabled") but the computer using the phone's switch is still online.
Ran QOS test with max # of connections while downloading a large file, just to add stress to the line.
Upstream jitter  1.2 msDownstream jitter  0.5 msUpstream packet loss  0.0 %Downstream packet loss  0.0 %Upstream packet order  99.9 %Downstream packet order  99.9 %Packet discards  0.0 %MOS  4.1 REGISTER ms  534 msINVITE ms  541 msBYE ms  297 msTestRingCentral QoS
Hi Andy,  You'll want to  Open a Case so our support team can look into this for you.
mike avatar image
mike answered
Hi Brice,  Take a look at the instructions on this page:
Resolving Phone Registration Errors: URL Call Disabled
If you still have problems please open a case and let us know the phone, etc with the problem.  Open a Case
