alyssia avatar image
alyssia asked kim answered
Queue Name Display on Incoming Calls
How can I display the queue name for incoming calls?  I would like to use a different script based on the inbound queue and would like to display the queue name when an agent receives a call.
topic-default
robbenn-frenette138 avatar image
robbenn-frenette138 answered
You can't change the name of the call as far as I know, but you can set the system to tell the call receiver to press one to accept the call from the "ABC Call Queue"
kim avatar image
kim answered
Rob is correct in this situation.  Thank you very much for your help her, Rob.
Kim
