employee-management286 avatar image
employee-management286 asked benjamin-dean answered
Sending Fax Limitation
Is there a limitation on how many recipient can add in a single request and how many sent request a day?
faxapilimit
benjamin-dean avatar image
The older FaxOut API:  https://service.ringcentral.com/faxoutapi/ has a limit of 49 recipients. Once you hit 50 you'll need to use the FaxResource per this documentation:  http://success.ringcentral.com/articles/en_US/RC_Knowledge_Article/6643
OR
The newer Connect Platform API's Message resource for Fax:  https://developers.ringcentral.com/api-docs/latest/index.html#!#FaxMessages.html has the same limitations for recipient quantity, but expanded functionality beyond these limits.
