Paul McGarr avatar image
Paul McGarr asked Paul McGarr commented
RingCentral App for iOS does not Ring or Notify
Current version iOS, iPhone 6, current version RingCentral. No ring, no notification. Notification used to work, notification settings for RingCentral app are all set correctly. Account setting are set correctly too, at least they are set as they were when app used to work. This app is nothing but trouble, I miss more calls than I get. For a business product this shouldn't be.
topic-default
mike avatar image
mike answered
Hi Paul, there are a variety of settings that need to be checked if the mobile app is not ringing.
The first thing to check is:  Log into that extension and go to  Call Handling & Forwarding > Desktop & Smartphone and make sure it's set to the "On" position.
If this does not work or there's another issue, let us know.
Paul McGarr answered mike commented
It is on.
17 comments
OK,  Next can you tell me if the Softphone Rings but the mobile app does not?
Also, do you have it set up to forward to any numbers after a certain number of rings?
Paul McGarr avatar image Paul McGarr commented ·
I do not have a PC softphone, just the mobile app. I do have a hard phone that does ring. I am not forwarding at all.
Ok, in this image, directly below the "on" switch, there's a field to set the number of seconds before forwarding begins. What do you have it set to?
Zero
OK, so it's forwarding to the deskphone instantly then. You'll want to set it to about 15-20 then test it again.
Shelley Alonso avatar image
Shelley Alonso answered
My frustration with this has come from the IOS version.  I've discovered that while Android users can swipe the app closed and it continues running in the background, IOS truly shuts the app down and prevents it from running in the background, which prevents incoming calls....
kim avatar image
kim answered
Shelley,  Apologize but this is an apple setting not a RingCentral Setting.  In an apple device, if you double click your home button and swipe an app upward it closed it and prevents it from running in the background.  This is an IOS security policy set by apple.  RingCentral cannot remotely launch an app.
Kim
Paul McGarr answered Paul McGarr commented
But this is not my issue. I am not closing the app. My issue is back. No ring, no notification. Just missing calls. Based on everything else consistently working normal and the RingCentral app working occasionally at best, I'll assume this is the app. Another major disappointment with my RingCentral service. I don't have a desk job. I need this functionality. Is this a known issue?
5 comments
Hi Paul,  There are no known issues that would cause the app to only work part of the time. This is likely a configuration issue. A setting on the online account, the mobile app, or the cell phones wifi/data settings, or a combination of these things.  I think the most efficient way to help you out is via phone support if you want to give us a call.
I'll try later, around 7:00 eastern. I've done this before though...
FYI, I decided I must be crazy. So, I totally wiped my iPhone and started over as new. I installed just the RingCentral app. Worked like a charm...for a couple days. I left my phone brand new, didn't change anything or install any apps. Watched my wife call me. Nothing. Desk phone rang, but no notification. Checked the call log and the missed call was listed. Then my wife called again and it rang. I'm thinking if the app sits unused for an extended time it stops listening. Not sure how long it has to sit, probably dependent on resources available or something. Anyway, missing calls again. Not reliable, and now I am confident it is not me. Maybe it is my low usage pattern that sets me apart from the rest, but it is not me. Missing calls is bad for business and this is not acceptable for a business product. This is the second time I have been tempted to look for alternative service. One big strike for product reliability, and a previous huge strike for customer service .
Hi Paul,
If you've already reinstalled the app, and are sure all the configuration settings are correct, then the only other think I can think of is a poor/inconsistent wifi, or 3g/4g signal.
If none of these things apply then feel free to  Open a Case and let us know the model and OS version of the phone and version of the mobile app you have installed so our support team can do some research on this. Also, if you can document the date & time of a call that may be helpful as well.
Mike
I've already invested way too much time on this. Latest iPhone, latest iOS, and latest app version, and yes this issue continues on the app update from just a few days ago. Sorry, I am just out of patience. I have issues even in areas (home) with very strong wifi. Yes, wifi is on and connected.
