j-s avatar image
j-s asked mike answered
Feature Request: Bring back multiple lines when presence is active
Normally, once you turn on presence, phones with multiple lines would reduce the number of lines available to 2.
However, there was a workaround which functioned just fine until about 3 weeks ago, when an update turned it off.
We are having a difficult time functioning without this capability.  Our receptionist can't handle multiple incoming calls without the extra lines, and if I turn off presence then she doesn't have presence, and the sidecar is useless.
Please restore this function ASAP.
topic-default
mike avatar image
mike answered
Hello  J_S
Can you please use this link to  Open a Case.  I inquired with one of our Tier 3 engineers but they need more details. In the case let us know the phone number(s) involved, phone model etc, and describe the work-around you were referring to.
After you open the case, you can reply back her with the case number if you wish and we can follow it with you.
Mike
