mark-valpreda avatar image
mark-valpreda asked mike commented
Multiple outgoing calls with Yealink W52P
We have a Yealink W52P with 2 handsets. I am able to do the following:
  • Receive two incoming calls
  • Make one outgoing call and get an incoming call
But I cannot make two outgoing calls. Is that expected?
topic-default
mark-valpreda answered mike commented
SN: 1301214082505185
Odd....I was testing it again and it worked. I was able to make two outgoing calls. I only got the phones today, possibly got a firmware update?
You are correct. It probably just needed to update. Let us know if you need anything else.
kim avatar image
kim answered
Conversation made private.
What is the Serial Number of the Yealink?  What happens when you try to make the 2nd call?
