Joshua Stebell avatar image
Joshua Stebell asked ringcentral35 commented
Provisioning a Panasonic KX-TGP550
Hello.
I'm attempting to figure out how to provision a Panasonic KX-TGP hard phone. The company I work for uses most Yealink's which I have no trouble setting up. All I have to do for those is factory reset, pull up their IP address, follow it, log in, and then put in all the appropriate credentials. For this guy however, I haven't really a clue. Any and all assistance would be greatly appreciated. Thank you.
panasonic kx-tgp
ringcentral35 avatar image ringcentral35 commented ·
Great!  what it was the trick ?
Joshua Stebell answered
Okay. So, I've made some headway. I've gotten the this page, but still have no idea what information to put in where.
ringcentral35 answered
Enable the Web interface of the DECT base station
  • From the handset, press the joy stick to access the Main Menu, and select the Case icon (IP Service) > Network Settings> IP Settings. Take note of the IP address of the DECT base station.
  • From the main screen, press the joy stick to access the Main Menu, and select once again the Case icon (IP Service) > Network Settings. Open Embedded WEB, and change the option to ON.
  • Using a web browser, navigate to the web interface of the DECT base station, using the IP address noted previously.
  • The default username and password for the DECT base station are Admin and adminpass
Source  http://www.3cx.com/blog/ip-phone-configuration/provisioning_pana_kx-tgp500b01/
I think I'm making some sort of headway. Still don't know what to what what what yet though...
Fill the fields and repost the image.
I was provisioning a Konftel 300IP, Swedish conference phone, so should be far easy.
I legit had it working for 30 seconds. The blinking orange light went green on my phone. I made a call to my cell phone. It went through perfect. I hung up and the light immediately went back to blinking orange and I've been struggling to for the last 10 minutes to figure out what I did or what I can do. Halp.
