Kevin Callahan avatar image
Kevin Callahan asked danno147 answered
size of windows app too small
I have downloaded the Ring Central app for windows onto my Surface Pro 3. No matter how I size the app window, it is way to small to read, rendering the app unusable. I was told by Customer Support that there is no plan to make any changes to this, and that the only thing I can do is create a conversation here with the problem. So, here it is. When is Ring Central going to fix the app for windows 8.1 so you can actually see the text?
topic-default
danno147 avatar image
danno147 answered
Just FYI, I have the RC4Windows on my iPad and iPhone and it looks great.  Not sure if your issue may be related to a setting in the Surface or if RC has to do some adjustments with the APP for viewing in Surface.  Anyone have the APP loaded on a surface??
