Mike Henrie avatar image
Mike Henrie asked mike answered
Another softphone is running please exit before continuing when using Scan to Fax
my scan to fax (glad it back) tells me another softphone is running when I try to send a fax and to close it. I just installed the latest version to get this feature back so how do I get past this error message?
topic-default
danno147 avatar image
danno147 answered
In the past, whenever there is a new updated version of the RC4W, I've started by totally deleting the olde version ( all files) first before installing the new version.  And its not just RC apps - but I see it with a lot of apps and programs.  There's always a file or ext from the previous version that creates issues.  To me, sounds that it's still seeing your old softphone.  So try that, and if you still have issues - You might need tech support.  Good luck!
mike avatar image
mike answered
Danno's probably right.  Try to manually install any previous version. (maybe there's a copy of the old Legacy phone).  If you still have problems let us know and we'll be happy to help.
Mike
