colucci avatar image
colucci asked colucci commented
Error message - cannot receive fax
I am getting this is the error message - what does it mean and how can it be resolved:  "An incoming fax could not be received because a proper connection with the sender's fax machine could not be established."
topic-default
kim avatar image
kim answered colucci commented
Setting message to private.  What is your phone number and what is the number that is faxing you (if you have it). I'll look at it on the back and and test.
Kim
5 comments
colucci avatar image colucci commented ·
I have opened a case regarding this issue but have had no response.
What is the case number and i'll follow up with it...
And something to note, not all POTS line fax machines are compatible to send VoIP faxes...
That may be the issue (whatever it means!) as these are the only ones I cannot receive.  The case number is  03845844.  Thank you!
I've follow up with the case owner - she'll be contacting you shortly.
Thank you
