Creditors Discount & Audit Co avatar image
Creditors Discount & Audit Co asked Creditors Discount & Audit Co answered
Poor line condition / out of memory
How is it possible to get a message "Poor line condition / out of memory" sending an outgoing fax on a fax machine converted to using digital lines through RingCentral?
topic-default
danno147 avatar image
danno147 answered
Does the message appear in the display of the fax machine itself?
It appears on the Transmission Verification Report.
danno147 answered
That's what I thought.  Ran across this before.  How I diagnosed it was to send a test fax to a known "good" fax machine, from my machine.  That way I knew the connection was OK.  In one case, the fax machine settings had to be changed (I found them in the manual for the machine).  However, I did have one fax that wouldn't go through for one of our customers.  Even though I was able to send a fax successfully to hundreds of other customers. So many times the fax is dependent upon the receiving end.  See if that helps.
Thanks. I'll check it out.
