hebert avatar image
hebert asked hebert answered
How do I change the fax caller ID?
When I fax out it shows my name in the "From" at the top of the page.  How do I change that to just show the company name instead?
topic-default
mike avatar image
mike answered
There's not really a designed way to change the name the fax is coming from, but if you wanted to you could log into your extension and change your name to the company name under your User Details.  This may not be desirable for making calls though.
hebert avatar image
hebert answered
Thank you Mike!
