Marta Pedziwiatr avatar image
Marta Pedziwiatr asked kim commented
History
Hello, I would like to see the history from March of this year (2015)... It is not letting me do it...
topic-default
mike avatar image
mike answered
Are you referring to the Call Logs?   If you have set a custom date period and the calls aren't showing then someone probably deleted them. There's a good chance we can restore them if that is what happened.   If that is what you need, reply back and tell us what the phone number is. This has been made a private conversation so you can post details.
Mike
Marta Pedziwiatr answered kim commented
thank you so much! My fax # is 888-818-2155. I am interested in faxes between march 12th and april 20. If you could do it I would call you a genius!
2 comments
Your logs were purged on 10/27/2015. I will retrieve them from 01/01/2015.
Try now.
Did you get it?
I am interested in history of sent faxes thou!
