Nick Ellis avatar image
Nick Ellis asked kim commented
Two lines on phone
Having some issues with 2nd ling not ringing on Cisco SPA504's and 525's. I need to document this, and was wondering if anyone using Ring Central might be willing to assist?
Issue is, if 2nd call comes in - instead of ringing Line 2 on the phone, it rings Line 1 again (flashing, indicating there is another call on line1, instead of rolling down to line 2).
Would someone be so kind as to test this on their SPA504 or 525s and let me know if it works properly? If so, could you tell me the hardware/firmware version of your SPA?
Thank you very much!! Would be a huge help.
-Nick
topic-default
mike avatar image
mike answered
Hi Nick, for this issue it will be best to open a support case so we can look at specifics.   Open a Case
In your case notes be sure to include the serial numbers of the phones involved, and provide the phone numbers dialed etc. and explain the call flow. Is this a call queue etc?
Mike
Nick Ellis answered kim commented
Hi Mike, sorry if I wasn't clear enough - the issue is with another provider, which is why I was asking if anyone using ring central verify it's working fine on RC and the firmware/model number.
Thanks for your reply!
Nick- As long as the RingCentral Device is running the latest firmware, it should always have two lines...since the other lines would be presence values.
Chuck Fuscone avatar image
Chuck Fuscone answered
Hi Nick, I use the SPA series all the time.  Mostly the 525 but the 508 and 504 also.  The Ring Central System is working the way it has always.  If line one is busy line 2 rings on the phone.
the firmware standard on the SPA series phones is 5.7 I believe.
Are you considering RC for your needs?  If so let me know and I could help with a seamless transition
Chuck
Certified RC installer
chuckfuscone@gmail.com
