Kristanto Sean N avatar image
Kristanto Sean N asked
HTML CSS problem on email and fax
I am working on a website that generates a HTML code and sends it as an attachment to a fax machine to print. Everything works but for some reason, the font size ended up being too small while in the html code, it looked perfectly fine. What is the problem here? Is there a rule regarding the use of HTML CSS for fax printing? Thank you :)
topic-default
