larson avatar image
larson asked kim commented
Recording Conference Calls
You are supposed to be able to record a conference call using *9. Technical support keeps telling us this will workand it's listed as a conf call command, but it does not work. How do you get a conf call line that allows recording? *9 only works on Ring Out, it does not work for conf calls.
topic-default
kim avatar image
kim answered
Larson,
Can I have the case number?
Kim
larson avatar image
larson answered
oh that is my cell, I don't have a case number.  I just called tech support and was told I could record conf calls.
larson avatar image
larson answered kim commented
04162931
5 comments
Beth - that case was closed.  I created a new one for you ( Case # 04165522) and escalated it for further troubleshooting.  I was able to duplicate it on my end via softphone as well.
Did you see if it works on a hardphone? I want to test to see if the issue is only related to Softphone or Hardphone, or all channels are not working.
You should see the new case in your case history.  Feel free to "Add Comments" with any additional information that will go directly to the case owner.
larson avatar image larson commented ·
By softphone, do you mean a cell phone?  We have testing from Chicago landline, my cell phone, a landline and cell phone in Minnesota and a landline and cell phone in Portland.
No one using the conf lines below can record.  We can use things like #*5 to mute callers, but when you press *9, it doesnt do anything.
Let us know.  We have 85 interviews set up and we need to record them.
Beth
Conf Line: 605.562.3180
Host Code = 750-229-466
Participant Code = 375-114-733
Host Code = 724-428-278
Participant Code = 899-085-051
Host Code = 481-668-062
Participant Code = 240-834-031
Host Code = 421-582-177
Participant Code = 210-791-088
Softphone means the Desktop App.  So if you are using your cell phone, are you using the cell phone RingCentral App?
no, we just call into the conf line and host the call.  Do we need the app to dial the conf line for some reason?  I also don't undertand how to call the conf line from the desktop.  We use ring out on the desktop, but we never just call the conf line from the desktop.
You can dial the conference info directly from the cell app. Please download the RingCentral cell phone app for Android or iPhone.
Here is how to dial in through the Desktop App:
kim avatar image
kim answered
To find out your case number  please login to http://success.ringcentral.com/RCContactSupp and select Check my case status, and you will be able to see  case history at the bottom of the page.
