david-warren760 avatar image
david-warren760 asked kim answered
Voicemail on TPG500
Just got a TPG500 setup.  Dialing and Receiving calls works fine.  When I dial *86 I connect to the Voicemail attendant, but the system is not hearing me enter the PIN or acknowledging when I press #.
Is this possibly a setup issue?
topic-default
kim avatar image
kim answered
This is a 3rd Party unsupported device. You can try to contact support to check the provisioning, but it's not supported.
