febe-zabala avatar image
febe-zabala asked kim answered
After deauthorized this computer, what's next? I can't even authorized back my computer. And I still have a blank screen. Nothing to show.
After deauthorized this computer, what's next? I can't even authorized back my computer. And I still have a blank screen. Nothing to show in my Ring Central App
topic-default
derrick-bozkurt240 avatar image
derrick-bozkurt240 answered
Febe,
There are a couple of things that could be causing this problem. The most common resolution is to quit the application and clear the App Data folders for the softphone from your PC. It sounds like you may have already attempted some of this, but just in case, here are some good directions:
NOTE:
Windows 10 is still in beta
Troubleshooting Desktop App crashing or  blank screen:
1)  Uninstall the old LegacyIf you still have it installed onto your PC.
2) Make sure you have the most  current version of the new softphone installed.
3)  Logout & Close the new one ... also close it from running in the background from your task bar.
4)  Deauthorize the PC (see Image 2)
5) Go to Computer > Local Disk (C:) > Users > pick user > Appdata > Local > RingCentral >  Delete the two folders.  (see Image 1)
If you don't see "App Data" at the top above Contacts just click on the navigation bar above, enter in "\appdata" (mind the backslash), then hit enter.
6) Log back in and test.
(Image 1)
(Image 2)
Once you log back into the softphone, it will automatically authorize that PC, so no action is required from you on that part.
If this does not resolve your problem, we recommend calling into support at 888.898.4591 for additional troubleshooting. Alternatively, you may open a case with our support team for further assistance.
Regards,
Derrick Bozkurt
Tier III Technician
kim avatar image
kim answered
Please see troubleshooting steps listed here
