U.S. business account
Currently, if Ring Central desktop application is the active window (the window is selected, or the incoming call popup is active), the "Pause" command will not work. This means that if a call comes in, I have to manually switch to the application playing music, then switch back to the RingCentral popup, and then answer the call. If I don't do that, then music is playing over the headset when I answer. Is this intended functionality?
I need to be able to execute the pause command without switching windows in order to efficiently pause music and answer a call. If Ring Central assumes control over the F-Keys, could it run the pause command when the answer button on the popup is clicked?
I have ensured that I have no other keyboard commands mapped in Ring Central to the keys I am using to pause the music. I have observed and replicated the issue both with the Ring Central desktop application, and with the pop-up.
I have a Logitech K740 with media controls build into the F10-F12 keys, and I normally am running the Spotify desktop application. My OS is Windows 7. I am running the latest version of the ring central desktop application.
