voicemail1466 avatar image
voicemail1466 asked voicemail1466 commented
Call Handling: Set an Advanced Rule by local area code.
I'm trying to create a rule based off of an area code. I'm wanting to route all local calls to a specific extension. Is this possible and how do I do it? When only adding my area code (512) it doesn't seem to trigger the rule when calling from a phone with that area code.
topic-default
voicemail1466 answered voicemail1466 commented
I meant area code. Corrected in question.
3 comments
danno147 avatar image danno147 commented ·
oh, then place a 1 before the area code and that will work for you.
so for 512, enter 1512.
voicemail1466 avatar image voicemail1466 commented ·
Much appreciated. Thank you for the help.
