front-office1739 avatar image
front-office1739 asked kim commented
Set # of rings instead of by seconds.. Can we please update this as soon as possible
topic-default
jb-ferguson avatar image
jb-ferguson answered kim commented
Set the  Ring Duration for the forwarding number, where 5 seconds is approximately equivalent to 1 ring.
You can find this information in the Knowledge Base article located here:
https://success.ringcentral.com/articles/en_US/RC_Knowledge_Article/5-10-Editing-your-Extension-s-Bus...
3 comments
I would not recommending going too low (maybe above 10-15 seconds-but test it on your network), because you will need to allow time for routing (this is dependent on your network and ISP).
There is no way to control how many rings you will hear on your phone, nor the user on their end, because every network/ISP is different.
front-office1739 avatar image front-office1739 commented ·
yes and 10 seconds is equivalent to 2 rings but im getting 3 calls in 10 seconds and 2 calls in 5 seconds.  And I need it to ring twice
