Getting a lot of contacts that last about 45 seconds but end up with no fax received and the status is " Fax Receipt Error"
I am having this issue from one customer using a digital fax solution in their environment to send faxes from a large number of MFDs.
I saw the settings for making an analog fax machine talk to yours, but shouldn't you be able to handshake with the customer's digital system?
I was able to receive a fax just fine from an analog fax whose settings I don't know.
t.
