Natasha Ah Jack avatar image
Natasha Ah Jack asked mike commented
Call Handling: how to have Mobile App get incoming calls
We currently have our call handling settings configured to first go through our main line (desk phone), then if not answered the call is forwarded to my personal iPhone. I want the call to come through my iPhone through the RC mobile app so I can then easily transfer the call to the right person. How can I configure this?
I read that you need to turn on the desktop apps & smartphones option, however I don't want the call to ring there first. I want it to ring through the main line first, then the app when it is forwarded to my personal phone. Does that make sense?
topic-default
danno147 avatar image
danno147 answered
If that's the case, in CALL HANDLING, turn off Desktop apps & Smartphones on the 'main' line phone set.  Set the number of rings for the 'main' line phone.  Then select Call Forward to another phone, and enter locate your phone and extension.
danno147 answered
Then turn on your extension's Desktop apps & Smartphones and set the desired number of rings.
Natasha Ah Jack answered
No. My phone does not have a separate extension. Because I use my own device I don't have a user profile. I share the main line's profile. My cell number is listed as a secondary forwarding number.
kim avatar image
kim answered mike commented
To clarify - In order for you to have a physical device on your RingCentral account, it has to be place on an Ext.
Danno is correct - you'll have to have the calls fwd to your extension after they ring the main phone and then turn ON the Desktop App/Smartphone option in your call handling rules.
4 comments
Kevin, you may want to give us a call and talk about more details, but based on you first post above, if you log in under the main number + extension you should still be able to get the mobile app to ring. So, it's probably a configuration setting either in the web portal, or on the mobile app, or both.
Give us a call, and let us know which user it is, and how exactly you need it to work.
On a side note:   If a particular user has it's own direct number, they should log in with it instead of the main number + extension.
kevin-dorsey119 avatar image kevin-dorsey119 commented ·
Kim, In the past (a year ago) I was told that your cell phone app would not ring unless the extension was called directly. Is this still true?
I have all calls from the main company number forward to an extension(with no number) that was created to distribute the call to the other extensions(with actual users/phones). I want the ability to pickup the call from a smartphone app when logged into one of those extensions. As the administrator, I can get it to work on my phone because the main extension has the "notify administrator's desktop app" on. (side note: why does this setting which only refers to the desktop app affect the smartphone app?), but I cannot get it to work on another user's smartphone.
If it's possible, can you tell the procedure and can you clarify if the administrator referred to above is actually the Super Admin and why there's no reference to the smartphone in the setting for administrator's app?
Kevin,  I was just reviewing some older threads here on the Community and came across your post.  There are a lot of variables here depending on your configuration, there are several reasons your mobile app may, or may not ring.  If you are still having a problem, let us know.
Hi Mike, as it stands there are 2 of us that depend on the smartphone app to receive calls as stated above. Since I'm one of them and I'm the Super Admin(or overall Admin if that's different) I'm able to receive the calls but the other person I had to set up their phone app to login into the virtual? extension(not their actual extension with a number) that the main company number points to. After you guys implemented user roles I tried giving the user a Super Admin role and had them log the app into their real extension but it was still unable to receive the calls so I switched it back.
In the user settings for "Call Handling and Forwarding Desktop Apps & Smartphones  Notify administrator's Desktop app:" how is the administrator defined? Is it still true that the smartphone app can only be rung by a direct dial and not by a forward from another extension?
danno147 answered
So your main line rings on a separate ext and phone from your ext and phone?
