pete1 avatar image
pete1 asked mike commented
Ringcentral Desktop Huge Logs
I was just decommissioning a machine and used Windirstat to see what was taking up the most space... This image pretty much speaks for itself...  Large blue box is Ringcentral logfiles.  Location is:
 users\\username\AppData\Local\RingCentral\SoftPhone\Logs
Might check your client computers to see if there are logs taking up massive amounts of space.  This user didn't have any particular issues with the softphone app on her machine.  A cursory review of other machines hasn't shown anything strange.
topic-default
mark-engle1245 avatar image
mark-engle1245 answered
Thanks for sharing, Pete. The Windows desktop application has been particularly problematic for us so we're always looking for ways to keep our systems running as smoothly as possible.
pete1 avatar image
pete1 answered
I just looked on every machine's logs in my network, and this was the only machine with one log file that huge.  It was from last year, so it may have been a bug long ago from that particular version.
mike avatar image
mike answered
The log file can indeed get pretty large. In most cases it shouldn't cause any problems, but if you need to delete it see steps below.
Go to Computer > Local Disk (C:) > Users > pick user > Appdata > Local > RingCentral >  Delete the two files.
justin-davis1686 avatar image
justin-davis1686 answered
I've had this happen as well. Had someone's computer going slow and saw that their SSD was nearly full. Turns out there was a single log file taking up 60GB. A text file. I don't know how that happened. But it was nice to clear off half the drive with one file!
chris-nase avatar image
chris-nase answered mike commented
This happened to me and a log file was over 200GB inside the SoftPhone directory.  Can you please go into more detail about why the log files are this large?  Certainly this is a bug correct?  When can we expect it to be resolved?
Hi Chris, it's not a bug per se, but obviously 200GB is pretty large.  Our Product Team is aware that this can become an issue at a certain point. Sorry I/we don't have an immediate fix for this so for the time being, it's probably best to periodically clear the folders as described above.   Maybe at some point they can implement some sort of limit so that data is purged when it reaches a certain point.
Mike
