vibrantinvesting avatar image
vibrantinvesting asked kim answered
Messages & Notification: How does Admin view FAX sent to employee's ext if they don't have the employee's login?
One of my employees called and said they received a FAX.  I can see in the online Admin Portal call log that an incoming FAX was received.  It does not say what number received the FAX.  When I go to My Extension and check Messages, it does not show up.  My employee actually had to come to my house, on a Saturday, so we could get the FAX off of his phone app.
The closest thing I could find searching your support center was to keep our employees login information in case we need to use their login.  This is an unacceptable solution.  As admin, I can see all my employees calls, I can listen to their recordings, I have all their stats, I should be able to see any faxes that come in as well without needing their login info.
I have seen a similar topic from 11 months ago about not being able to see a fax from the admin portal.  Please tell me you have made some progress on this and let me know the ETA for when I will be able to see all incoming FAXs.  Thank you.
topic-default
kim avatar image
kim answered
The fax comes in under their Messages, so the Admin will need to have access to their Password if their messages are not set to be routed elsewhere.
